jcscoob Posted March 20, 2008 Posted March 20, 2008 (edited) Hi i am having a wee ecutek dispute with the missus ! Now to change from low boost to high boost, do you press the rear demister button (on full throttle) once or twice ? Edited March 20, 2008 by Jcscoob
st3ph3n Posted March 20, 2008 Posted March 20, 2008 It depends on what the rear demister is on. The switch occurs when the demister is turned from off to on. So in theory 1 click does it. You'll need 2 to get it back to whatever setting you were on.
jcscoob Posted March 20, 2008 Author Posted March 20, 2008 Cheers lads. Nik says twice and i was saying once/the same as Stephen ! Cars eh
st3ph3n Posted March 20, 2008 Posted March 20, 2008 You win then JC. I'll expect a cheque in the post?
jcscoob Posted March 20, 2008 Author Posted March 20, 2008 lol, im not sure if it will fit in the post, look out for the UPS van
frank c Posted March 20, 2008 Posted March 20, 2008 C'mon Jon....get in the car, you use the pedals and let Jake do the steering.....................then press the button to find out It'll be a laugh if anything
~ ~ Cal ~~ Posted March 20, 2008 Posted March 20, 2008 Twice in quick succession akin to a mouse click on the demister. WOt can either be in motion, stationary or even with just the ignition on
