TURBOEDD Posted January 30, 2008 Posted January 30, 2008 i have a classic turbo 2000, and my back brakes need changing. discs and pads. the calipers look really rusty is it possible to change from the standard calipers to 2 pots from an STI? if so how difficult will it be and will i have to modify anything?
wilky Posted January 30, 2008 Posted January 30, 2008 i have a classic turbo 2000, and my back brakes need changing. discs and pads. the calipers look really rusty is it possible to change from the standard calipers to 2 pots from an STI? if so how difficult will it be and will i have to modify anything? You can buy brackets that will allow you to put 2 pots onto the earllier discs. Im not sure what type you have but it can be done im sure. Do a search on SN and im sure you will come up with something. Callum W
TURBOEDD Posted January 31, 2008 Author Posted January 31, 2008 You can buy brackets that will allow you to put 2 pots onto the earllier discs. Im not sure what type you have but it can be done im sure. Do a search on SN and im sure you will come up with something.Callum W cheers for the reply,i'll get hunting for 2 pots and take it from there, hopefully it aint to difficult a job to do.
