20withascooby Posted January 25, 2008 Posted January 25, 2008 im goin to attempt to fit a flamer kit tomorrow on my car but in the instructions it says """" find a ignition live feed must be around 6 amps""""""" could i just put the wire onto my live wire that goes to my amp under my seat just i dont no how many amps that is or if it will work ?????# also does anybody have a drill bit i could borrow big enuf for a spark plug ??
granby Posted January 25, 2008 Posted January 25, 2008 Should be OK from the amp wire as i don't think they actually draw that much current, my flamer was run from the cig lighter
20withascooby Posted January 25, 2008 Author Posted January 25, 2008 and its ryt under my passenger seat which i good was guna mouth swtich neer stereo or my handbrake all lookes easy enuf just gtta make sure i get hole ryt in exhaust and dnt go ryt through the other side too lol il end up getting annoyed and drilling myself through the head if it dont work after
20withascooby Posted January 25, 2008 Author Posted January 25, 2008 just read that over and my speeling is bad think im dislekik lol as when im typing i reading it all out in my head what buttons to push and still do it wrong lol
dazzlers82 Posted January 25, 2008 Posted January 25, 2008 mines run or was run from amp wiring mate so should be fine just dont wrap coil pack in rags an tuck in spare wheel like i found mine when stripped out
wimpy Posted January 25, 2008 Posted January 25, 2008 mines run or was run from amp wiring mate so should be fine just dont wrap coil pack in rags an tuck in spare wheel like i found mine when stripped out Just make sure that you measure up the spark plug to the tail pipe so you know exactly where it goes and then take the back box off the car. Make sure you drill the hole slowly as the heat it will produce can warp the tail pipe. Buy the best spark plug normaly a v-tec plug as they have a long thread.mount the coil and timmer under the boot floor and check ht lead is the correct lenth. Iain
Montythegod Posted January 26, 2008 Posted January 26, 2008 I wired my flamer to the heated rear window wire... then you can switch it on and off from the front of the car.. and more to the point if you forget to leave it on it turns itself off after 10 mins or so. (handy for those police cars following you) I disconnected the drivers side spade terminal on the rear screen and extended it to the trigger box... Dont need rear defrost,lol
20withascooby Posted January 26, 2008 Author Posted January 26, 2008 all soughted few hours later with help of dazzler 3 drill bits,sum spit and sum car cleaner lol
Scooby Hoo? Posted January 26, 2008 Posted January 26, 2008 Lets see some pic's of it working then. We what pic's.
20withascooby Posted January 26, 2008 Author Posted January 26, 2008 will get sum tnite and a video will avto be nawty and turn it on on a public road
dazzlers82 Posted January 26, 2008 Posted January 26, 2008 will get sum tnite and a video will avto be nawty and turn it on on a public road so come on were is the vid you told me you had
20withascooby Posted January 27, 2008 Author Posted January 27, 2008 heres the video nice little pop at the end aswell http://uk.youtube.com/watch?v=7XgNzThcqJk
