pav Posted January 19, 2008 Posted January 19, 2008 Attempted a DIY de-tango on my blobeye last week, removed the front grill as advised, got all the relevant screws out, then I tried to remove the headlight, got a little movement but I was a bit nervous about giving it a good pull incase I broke anything. Is there a technique to getting them out? Maybe a certain direction to pull them? I read somewhere that it's a good idea to get to the light through the foglight hole, but the car has the PIAA drivers lamps and I don't fancy removing them Cheers Pav
gus the bus Posted January 19, 2008 Posted January 19, 2008 Attempted a DIY de-tango on my blobeye last week, removed the front grill as advised, got all the relevant screws out, then I tried to remove the headlight, got a little movement but I was a bit nervous about giving it a good pull incase I broke anything. Is there a technique to getting them out? Maybe a certain direction to pull them? I read somewhere that it's a good idea to get to the light through the foglight hole, but the car has the PIAA drivers lamps and I don't fancy removing themCheers Pav Pav, you really need to give them a firm push from behind. THey are held in on the outer edge with a couple of lugs. Gus
pav Posted January 19, 2008 Author Posted January 19, 2008 Pav, you really need to give them a firm push from behind. THey are held in on the outer edge with a couple of lugs.Gus Cheers Gus I know you're the de-tango'in expert
stocksy Posted January 21, 2008 Posted January 21, 2008 Attempted a DIY de-tango on my blobeye last week, removed the front grill as advised, got all the relevant screws out, then I tried to remove the headlight, got a little movement but I was a bit nervous about giving it a good pull incase I broke anything. Is there a technique to getting them out? Maybe a certain direction to pull them? I read somewhere that it's a good idea to get to the light through the foglight hole, but the car has the PIAA drivers lamps and I don't fancy removing themCheers Pav hi,done mine at weekend mate with no drama,30 mins a side,can help if like.
pav Posted January 21, 2008 Author Posted January 21, 2008 hi,done mine at weekend mate with no drama,30 mins a side,can help if like. Thanks stocksy, i'm offshore just now, i'll give it a bash when i'm home. will let you know how I get on cheers
seano Posted January 21, 2008 Posted January 21, 2008 Has anyone painted the inside of the headlights black and does it affect the beam pattern??
WUZ Posted January 21, 2008 Posted January 21, 2008 Has anyone painted the inside of the headlights black and does it affect the beam pattern?? Yes..................and......................No! Russell
Bailey73 Posted January 22, 2008 Posted January 22, 2008 Has anyone painted the inside of the headlights black and does it affect the beam pattern?? I have done this with the bugeye and they work fine still.
