Help Required!my Scooby Chirps!
Hi
As above.....when I press the key fob, my scooby lets out a chirp, and won't disarm so I can't start the engine - the alarm goes off!!!! ;)
Could it be that I need a new battery?????? :huh:
Jen(Who needs her scoob for the next Elgin meet this sunday)
Edited by SCOOBY-GIRL
I haven't been using the scoob for a couple of weeks now - have been turning her over every now and then.
I'm thinking Battery is flat.
Going to get some jump leads.
Jen
Dr Andy who is well known for his mechanical prowess highly recommends cuttlefish and Trill for a chirping Scooby :)
Right then thats: Jump leads, cuttlefish and trill ;)
Anything else?
Jen :huh:
Hi
As above.....when I press the key fob, my scooby lets out a chirp, and won't disarm so I can't start the engine - the alarm goes off!!!! :D
Could it be that I need a new battery?????? :rotfl:
Battery is going, mine did the same and got progressively worse because the alternator was on the way out, would only get one chirping start and then had to keep her running for a while to save up for another.... If you've not been using it much that will be the reason... might just need a good old run and that will be that... :rolleyes:
Battery is going, mine did the same and got progressively worse because the alternator was on the way out, would only get one chirping start and then had to keep her running for a while to save up for another.... If you've not been using it much that will be the reason... might just need a good old run and that will be that... :thumbup:
Tried jump leads on her last night with no joy! :guinness:
Got a new battery today - hey presto!!!! problem solved!!!!! :rolleyes::D
Thanks
JEN :rotfl:
