butler Posted September 13, 2007 Posted September 13, 2007 Going to get an Apexi power fc beggining of next year and was wondering if it can raise and controll boost levels or would i need a boost controller (i.e avcr)? Was also wondering if anyone could clarify what the standard boost is on an sti ver3? I have a boost gauge on the car (unknown make) which sometimes goes to 1.1, 1.2 bar, and the engine is totally standard! Though the boost is arond 0.9 standard? Could the gauge be giving a false reading?
the squiggle Posted September 13, 2007 Posted September 13, 2007 Going to get an Apexi power fc beggining of next year and was wondering if it can raise and controll boost levels or would i need a boost controller (i.e avcr)? Was also wondering if anyone could clarify what the standard boost is on an sti ver3? I have a boost gauge on the car (unknown make) which sometimes goes to 1.1, 1.2 bar, and the engine is totally standard! Though the boost is arond 0.9 standard? Could the gauge be giving a false reading? The final boost figure will depend on a number of things Fuel pump...std or not Fuel Pressure Regulator....std or not Intercooler ..... std or not Boost Control ...... std or not. Induction..........std or not Exhaust....std or not Condition of internals and compression Version 1+2 run 0.9 peak Version 3 is about 1.1 - 1.2 depends on ambient temp With the right basic bits you should be able to pull about 1.4bar out of it but the VF23 turbo might throw a wobbler so maybe about 1.2 1.3
butler Posted September 13, 2007 Author Posted September 13, 2007 Only modification is a cat back vortex system and green panel filter everything thing else is standard.
the squiggle Posted September 13, 2007 Posted September 13, 2007 Only modification is a cat back vortex system and green panel filter everything thing else is standard. Probably about the 1.2 mark Relibility and mid range punch would be the best gains after remap
butler Posted September 13, 2007 Author Posted September 13, 2007 Cheers m8! Any advice on the boost controller?
