Engine Light
Engine light came on today. Car seems to run fine but obviously something is wrong. I live in Dunfermline and car is 51 WRX Turbo. Did flash once or twice last month for about 20 seconds but went off only seemed to happen when accelerating from 2-3K in 4th gear. Obviously dont want to drive the car too far so any recomendations on where to take it for the best advice at the right price would be greatly appreciated.
Thanks in advance
Mike.
Thanks in advance
Mike.
Take it to a Main Dealer and ask them to check the code stored in the ECU.
Dont ask them to fix it just to tell you what the code is. If it something simple get the dealer to sort it but if it is something a bit more technical, post the results up here and i am sure a WRX owner will advise accordingly as to the best place to repair the problem
Thanks for the advice. I've got 2 options take it to either Cupar or Falkirk both roughly the same distance or buy OBDII cable around £45 and check it myself on laptop. Has anyone ever used these cables and software. I'm electronic test engineer and it all seems fairly straightforward plus I'll have the kit for any future problems (Don't intend ever buying anything other than a Subaru again). Again any further comments would be useful.
Thanks again
Mike
here m8 try this These codes are not documented in the Impreza Workshop manual but are mentioned in other Subaru Documentation (and can be decoded by a Select Monitor), these may or may not be applicable to the Impreza.
Code ITEM
11 Crank Angle Sensor or Circuit
12 Starter Switch or Circuit
13 Cam Position Sensor or Circuit (TDC Sensor on Justy)
14 Fuel Injector No. 1 (Legacy, Impreza, Justy, SVX)
15 Fuel Injector No. 2 (Legacy, Impreza, Justy, SVX)
16 Fuel Injector No. 3 (Legacy, Impreza, Justy, SVX)
17 Fuel Injector No. 4 (Legacy, Impreza, SVX)
18 Fuel Injector No. 5 (SVX)
19 Fuel Injector No. 6 (SVX)
21 Coolant Temperature Sensor or Circuit
22 Knock Sensor or Circuit (Right Side on SVX)
23 Air Flow Meter or Circuit (Exc. Justy)
24 Air Control Valve or Circuit (Exc. Justy)
25 Fuel injector No. 3 and 4 (XT-6)
26 Air Temperature Sensor (Justy)
28 Knock Sensor No. 2 (SVX, Left Side)
29 Crank Angle Sensor (SVX, No. 2)
31 Throttle Position Sensor or Circuit
32 Oxygen Sensor or Circuit (No. 1, Right Side, On SVX)
33 Vehicle Speed Sensor (VSS) or Circuit
34 EGR Solenoid or Circuit
35 Purge Control Solenoid or Circuit
36 Air Suction Solenoid Valve (Impreza)
37 Oxygen Sensor (No. 2, Left Side, On SVX)
38 Engine Torque Control (SVX)
41 Air/Fuel Adaptive Control
42 Idle Switch or Circuit
43 Throttle Switch
44 Wastegate Duty Solenoid (Turbo Models)
45 Pressure Sensor Duty Solenoid (Turbo Models)
45 Atmospheric Pressure Sensor or Circuit (Non-Turbo Models)
46 Neutral or Parking Switch or Circuit
47 Fuel Injector
49 Airflow Sensor
51 Neutral Switch (Manual Transmission Models)
51 Inhibitor Switch (Automatic Transmission Models)
52 Parking Brake Switch (Exc. Justy)
53 Fuel Pump or Circuit
54 Choke Control System
55 EGR Temperature Sensor or Circuit
56 EGR System
57 Canister Control System
58 Air Control System
61 Fuel Tank Pressure Control Solenoid (Impreza)
62 Fuel Temperature Sensor (Impreza)
63 Fuel Tank Pressure Sensor (Impreza)
64 Vacuum Line Control Valve or Circuit
65 Vacuum Pressure Sensor
66 Sequential turbo system
67 Exhaust valve solenoid (positive pressure)
68 Exhaust valve duty solenoid
71 Ignition Pulse System
73 Ignition Pulse System
74 Ignition Pulse System
88 TBI Control Unit
these are all the sensor codes and stuff from subaru
these are some others
Code ITEM
11 Crankshaft position sensor
12 Starter switch
13 Camshaft position sensor
21 Engine coolant temperature sensor
22 Knock sensor
23 Mass air flow sensor
24 Idle air control solenoid
31 Throttle position sensor
32 Oxygen sensor
33 Vehicle speed sensor 2
35 Purge control solenoid valve
42 Idle switch
44 Wastegate control solenoid valve
45 Pressure sensor –Pressure exchange solenoid valve
51 Neutral position switch
Thanks for the advice guys going to order one of these
http://cgi.ebay.co.uk/Car-Fault-Error-Code...1QQcmdZViewItem
Will let you know how I get on. Garage were going to charge to read error code and then re-charge me to reset after I had carried out repair if I had done so on my own rather than let them fix it. So unit should pay for itself and I'll have the kit for future problems. Plus I don't fancy driving the car 40 miles to the garage when I don't know whats wrong.
Thanks again
Mike
