evokiller Posted September 4, 2007 Posted September 4, 2007 hi guys can any of you tell me where this is located on my car it is a 2000 turbo x plate my cel light has come on and its indicating this so i need to find out were it is located and replace it cheers evokiller
jamie_wood Posted September 4, 2007 Posted September 4, 2007 The sensor is on the gearbox, the plug that connects the sensor to the loom should be located on top of the bell housing, under the intercooler.Try checking there before you go under the car to pull the sensor out. Also try a reset to clear the code. Good luck
