Help Lambda Sensor
hi guys just moted the scooby and was told it failed on exhaust emmisions lambda reading after second idle outside specified limits was advised it might just need a clean con any of you tell me what to clean the sensor with as i told the guy it would be back for retest in the morning cheers evokiller :icon_pray:
  • 1 month later...
hi guys just moted the scooby and was told it failed on exhaust emmisions lambda reading after second idle outside specified limits was advised it might just need a clean con any of you tell me what to clean the sensor with as i told the guy it would be back for retest in the morning cheers evokiller :rolleyes:
Did you get this sorted? Mine has just done the same with HC levels,
