Spark plug advice ?>??
I could be wrong, but NGK Grade 7's have always done me fine.. and IIRC are recommended when running higher boost than normal. Andy F recommends fitting them before turning up for a re-map to limit the possibility that the normal grade may not perform well once boost rises. [:)]
Cheers,
Grant
Cheers,
Grant
Yip thats the ones Andy likes, but don't adjust the gap on them they come set at 0.7 which is spot on
and only tighten them hand tight.
Hi all
I've yet to change the plugs on mine..... they look like a bit of a nightmare to get at. I've changed plenty in the past on both steel and alloy cylinder heads but they've all been easily accessible.
Any advice welcome. Standard plug socket ok for access?
Why only hand tighten when replacing? Are they prone to seizing?
 Cheers.
i dont have an airbox on my car so the left hand plugs werent too bad to do,just awkward.on the right hand side take
battery and water bottle out of the way and not too bad.not sure if a classic is any harder than a newage though.
when tightening new plugs-hand tight and then a half turn should do the trick.
jim
  • 2 weeks later...
Well i took the safest route lol got Grant and the guys @AWD to change mines, i went for a set of Denso Iridium plugs and i de-catted the car as i was there lol
Thanks again for all help and advice.
Daz
