frank c Posted June 17, 2007 Posted June 17, 2007 Right folks, need some advice. I've just fitted a Hyperflow TMIC and it sits very close to the bonnet and scoop so was thinking about fitting some kind of mesh grille to protect it. I,ve had a quick look about but I'm not sure what size to go for .. ie; size of holes on the mesh..if you get my drift. Too compact will surely restrict air flow and too big will let small stones and the like in.. What do you think ? Where would be the best place to source some ? cheers.
st3ph3n Posted June 17, 2007 Posted June 17, 2007 Frank, B+Q have LOADS mate. Halfords have mesh too but it's nae cheap and well Mesh is Mesh really. Try experimenting with it. You're never going to get fully away with stones without blocking if off completely, but that helps no one really.
frank c Posted June 17, 2007 Author Posted June 17, 2007 Cheers Stephen. B&Q it is then. Just thought i'd check here first to see what everyone else has fitted. Trial and error here i come []
st3ph3n Posted June 17, 2007 Posted June 17, 2007 There's a project later in the summer to fabricate the Lower grill mesh for my car. Think I can do it all in for less than £10. Prodrive one is about £150 or something. B&Q is a fine choice []
