Recommendations for Heat Wrapping
Appears to be alot out there want to get a good quality one for wrapping the down pipe, have seen a kit from thermotec that includes  wrap, ties and a turbo wrap was wondering if it was a good product.
Also would it be advised to apply a spray sealant as well to the wrap.
CHeers
Bandito
Spray it with HT spray paint after as that can stop the water soaking into the wrap and have the exhaust smelling like a wet dog......................unless you like that sort of thing!
If money is no option, I've found a place up here that can do Ceramic Coating on the exhaust, etc?
Russell
  • 2 weeks later...
Having tried many brands of exhaust wrap, I have settled on DEI which I buy in frequent batches of ten rolls, 50' X 2". It is not the cheapest but is economical to use. It has a stitching down the side which makes judging the overlap easy and consistent. It is applied damp, not wet.
I stopped spraying the wrap because I found it made the wrap brittle after a lot of heat recycling and was then prone to flaking.
