4Hero Posted November 23, 2006 Posted November 23, 2006 I wonder if anyone can help? I have hunted and hunted to find somewhere to get a lower black mesh grille, just like the upper one, but had no luck. Would any of you guys know where I could purchase such an item? any help would be appreciated [Y] Neil.
4Hero Posted November 23, 2006 Author Posted November 23, 2006 Paul N over on the general section just pointed me in the direction of Revolution in case anyone fancies one too []
Ian Coulter Posted November 23, 2006 Posted November 23, 2006 Hi, I have just got & fitted one from Revolution, along with their front splitter. Both went on fairly easily and improve the front of the car. Mine is a black one too! Regards, Ian PS - Forgot to say that Subaru do a plastic(?) Prodrive one at £150 part no SACC2615. This is the one that they fitted to the UK spec D.
4Hero Posted November 23, 2006 Author Posted November 23, 2006 Thanks for that Ian [Y] Did you have to drill anywhere to fit the grille?
Ian Coulter Posted November 24, 2006 Posted November 24, 2006 Neil, Yes, you need to drill 3 holes for the fixing screws. There are then 3 metal load spreaders to go behind the panel. I replaced their small rubber washers with larger tap washers. All very easy to do and quite inconspicuous when fitted. It certainly looks good and should come as standard! Ian
Ian Coulter Posted November 27, 2006 Posted November 27, 2006 Hi, Have you ordered one yet (while they still have £20 off)? You are welcome to have a look at mine, if it would help you to decide. I usually pass around the west side of Edinburgh a couple of times a week. Regards, Ian PS - Nice photos on the other thread. I assume your wheels are actually gold.
