technical advice needed
when the car is stationary and you rock the steering back and foth there is a clunking noise.
on inspection of the car undrerneath the track rod ends are fine as are the cv"s but the inner bearing of the driveshaft (next to gearbox) has a bit of play could this be the problem? or is there something else i should check? the noise is definately coming from this area of the car just cant put my finger on it.
thanks les.
Are the pins in place which secure the driveshafts to the gearbox shafts?
If you can check underneath and see the track rod ends are okay. What about the anti-roll bar bushes? Check the wheel bearings have no play. Check the track control arm bushes for play (get someone to wiggle the steering wheel while you have a look)
Might not be underneath at all. Could be the steering column shaft has play in it and could give a clunk. Get your arm down by the turbo and try and check the steering UJ for play.
hi meant to say its a sport
checked the wheel bearings they check out ok as are anti roll bar bushes.
gear box pins are in place but have a little play.
the track control arm feels to me that thats were its coming from could be wrong can feel the clunk when holding it but cant really feel any play in it.
very confused.
