harry_hood Posted October 30, 2005 Posted October 30, 2005 Car has just failed its mot on the passengers side front brake pipe,are the brakes on the subaru quite easy to bleed,or is there any problems with the system
IanJ Posted October 30, 2005 Posted October 30, 2005 No more of a pain than any other car i've had to do. I'd take this opportunity to flush out the whole system. I'm guessing if one pipe is rusting then the rest will be a bit tatty too. Carefully check them and replace. Any decent motorfactors can make up a set for around £30.
