Iaing Posted October 26, 2005 Posted October 26, 2005 Ok I was fitting uk 300 lights last night and got stuck trying to remove the standard terminals from the wrx plugs on the end of the headlight loom. Apparently you can use a pin to push something down inside the plug to remove the terminal but I gave up after about an hour of trying. These terminals are supposed to fit into the brown plug supplied with the lights which when plugged in will control the levelling motor. So does anyone have an easier way of removing them? I beleive there is a tool for this but i spent my lunchtime driving round aberdeen looking for somewhere that sold it and not one did. I did end up fitting the lights anyway without the levelling but would like to sort it. Help! Iain *** edited ***
fai17 Posted October 26, 2005 Posted October 26, 2005 Why don't you just take the undertray off or take one of the fixings off and stick your hand in to rummage for it.
Iaing Posted October 26, 2005 Author Posted October 26, 2005 Had to be somewhere so didnt have time to take it off. I did have a feel about but couldnt get to it. Iain
