HKS Fuel Cut Defender
"A fuel cut defender is an essential modification if you want to increase the turbocharger boost over the factory limit. Whilst they are not recommended for novices or the early stages of modification they come into their own when high boost levels and power outputs are required. In fact, short of installing a fully programmable ECU, there is no other effective way of removing the factory fuel cut."
I think it basically means you can fool the ECU into stopping the fuel cut at the factory set limit??
