pornodan Posted October 1, 2005 Posted October 1, 2005 hi guys i have a warning light which has come on in the middle of rev counter and speedo it is just above the seat belt warning light (classic scoob).it is a circle with an explamation mark in the middle. im not really clued up on these , does anyone know what this is warning you of. thanks
Dalthegooner Posted October 1, 2005 Posted October 1, 2005 Check your brake fluid, if thats not low then It will probably be low brake pads. Thats what that warning light usually means. The only pther thing it can be is that you've not let off your handbrake properly or your handbrake switch is knackered.
pornodan Posted October 1, 2005 Author Posted October 1, 2005 thanks dal must be my brakes, as handbrake has a seperate warning light .
