meko Posted May 5, 2005 Posted May 5, 2005 could anyone out there tell me if it would be ok to run my 02 wrx with 3/4 of a tank with normal fuel and then the other 1/4 with optimax or should you just go with the full tank of optimax? would there be any harm in it?
wrxmania Posted May 5, 2005 Posted May 5, 2005 It would run OK in an emergency but not as well if you do that often. If it is relatively unmodified then it will run fine, if a bit sluggish. Try to give it a good hard run for a while when you get it filled back up with Optimax only to help set the ECU (or just reset it). Brian
