poss dead battery
Guest
hi guys
can a battery die overnight?
thanks
alan
do you know anyone with a drop tester...or do you have a multimeter...you can check the charging and see if something is draining it
naa, it would have to be bad to drain it dead in a night
i take it all the terminals are tight...not corroded...
i would charge it up as much as you can then get it drop tested, this will show any dead cells, unless it is a sealed battery
