Grumbler Posted September 28, 2004 Posted September 28, 2004 i took my car back to the garage and they said that it was losing a lot of boost. would this cause me to loose a bit of power?
Guest Posted September 28, 2004 Posted September 28, 2004 to right it would it is the boost which helps pressurise the combustion within the piston so less boost less power! get them to sort it if u only just bought it!
Allan Posted September 28, 2004 Posted September 28, 2004 Yeah you would lose power.It could just be a leaking pipe?
Grumbler Posted September 28, 2004 Author Posted September 28, 2004 weel they are going to replace the solenoid in the boost controller and the actual boost solenoid and if its still not working then they are going to check the pipes for an air leak. i think thats what they said anyway.
