tomwrx08 Posted April 28, 2011 Posted April 28, 2011 can anyone tell me where to get these asap, have tried a few breakers etc but none, had a set lined up but the pr1ck has fecked me about and turns out he didnt have them so had to go through paypal for to get ma money back, any help or info would be much appreciated cheers tom
sti pretender Posted April 28, 2011 Posted April 28, 2011 I assume your looking at a brake upgraded. The STI (R180) hub won't fit a WRX (R160) as the driveshafts are different sizes. The backplate will and with a conversion kit will let you fit bigger brakes.
thebigfelly Posted April 28, 2011 Posted April 28, 2011 thats where i had to get my hub from as it was buckled http://www.japperformanceparts.co.uk/
tomwrx08 Posted April 28, 2011 Author Posted April 28, 2011 Cheer lads. Im in the middle of a 6. Spd conversion from an 02sti on my hawkeye wrx. I had everthing except the rear hubs as i was told my shafts would fit but they dont at the rear sti shafts are thicker so dont fit my hubs.and the ends cant bebchanged as the shafts are a different thickness. So i bought a set of hubs and was told the were complete but the twat sent me them and had cut the abs and handbrake cable.so i would need to completely strip down the hubs to replace them. So im about to send the hubs back and the garage im using have found a place that are going to make me new shafts that will fit the sti rear diff and my hawkeye rear hub.
