boab type ra`s project
Time has come to slightly modify the ra its not goin to the quickest or nicest or cleanest but am goin to give it a bit a bit of a clean up and give it a bit more power. i am goin to take the engine out and give it a bit of a clean and a slash of pain gointo paint inlet manifold and rocer cover white with blue detailing all hoses blue and cable bucts blue also have blue heat wrap. the calipers from kenny cheers m8 are getting painted white with blue subaru, looking to get white wheels with blue nuts. my list of mods r bellow if av mist anything please let me know
td05 20g
550 injectors
walbro fuel pump
rcm headers with venturi up pipe
rcm down pipe
c&c system
front mount intercooler
apexi induction kit
apexi ecu
av got pics the way it is now and will post up with updates but at the moment am havin problems uploading can1t remember how to do it.
Edited by boab type ra
td05 20g
550 injectors
walbro fuel pump
rcm down pipe
c&c system
apexi induction kit
apexi ecu
Looks good to me :)
  On 31/03/2011 at 05:12, soundie said:
:thumbup: for the white manifold !
what sort of scooby is it? a WRX RA? with redline a 7k?
its a wrx ra m8.
seen you up at knockhill the other weekend looked good and quick on the track.
  On 31/03/2011 at 19:48, boab type ra said:
its a wrx ra m8.
Ah nice one! yeah sub 60 next time, then I'll not care for times :)
keep us posted on the project!
the project has hit a snag been changed shifts at work so my funds have took a big hit so some of the tuning won`t be getting done till later in the summer so as it stands not sure what my funds will allow but it will b attending the next show at knockhill in may i am in the progress of removing the inlet manifold but weather and work is holding me back plus the high temp paint i orderd came but was clear coat so am waiting on white paint coming
Nowt wrong with the weather today :thumbup: i'm sure you'll get there. There's no point in trying to rush things. you'll get it how you want in the end m8.
Johnny.
inlet manifold removed and air con now removed waiting for the paint to come. will get some updated pics up soon ma ma maws new dog chewed the cable to pload the pics to my laptop.
  • 2 weeks later...
the paint is here for the manifold thats ma project for next week. the wheel bearing is finally done and am nearly finished the calipers. took some pics today
well had a bad day chipped the paint on manifold so had to remove and paint again no pics am too embarassed so wil get it fitted on tuesday and take pics of the finished engine bay. will get the front brakes on to nd get the pics on here
old brakes
new brakes
the new brakes don`t fit so its been a waste of time the caliper is about 5mm too far away from hub sopart of the pads don`t have contact with disc plus the wheels that i got off a sti ra won`t fit the calipers av scrapped the paint off the caliper so its going to b months bfore the ra is on the road am absolutly gutted will need to get a new caliper because i gave my ex mine because hers was siezed. the pads and discs r shagged on mine so buy the time i save the money to do this its going to b a couple of months everything that could go wrong has gone wrong am completely gutted getting close to a match and a gallon of petrol and start again
I take it the wheels are off an early ra? What car did the calipers come off? I've got 4pots on mine (from sti5) and they went straight on. Your welcome to come round and have a quick look to see what the problem is but you'll need to be quick as they are coming off asap.
you could buy em if your interested.. :lol: cheap.
Johnny
i am a grade A moron i should not be let near a tool box without supervition have been racking my brains and said to myself they must fit so took off the caliper and disc and bam i left my socket on the nut for the dust plate so the disc was not sitting proper and was itting out a little at the bottom left 1 problem solved just need a set of wheels to suit the calipers
Thank feck for that would have been gutted for you if the calipers hadnt fitted
kenny
got the gaskets for the manifold this morning so fitted manifold and took som pics its not completly built still got alot of work to do so this is the progress so far let me know what you guys think
