cullenmin Posted March 7, 2011 Posted March 7, 2011 Hey folks, Got a problem with my boost, seems | have far too much of it. Upon accelerating I'm sure I got fuel cut and seen the boost had spiked up to 1.8 bar and 90% on the solenoid (AVCR boost Controller). Tried again, but a bit gentler on accelerating and boost was going well above the 1.5 bar that it is set at. So put the AVCR setting to OFF so that I would be on wastegate pressure but i was still boosting far too high. My question is, I suspect the actuator is seized or jammed hence giving me lots of boost, so with the engine off i tried to move it by hand. Should I be able to move the actuator on the turbo with my hand or is it jammed as suspected? Thanks for any info/advice on this Rich
cullenmin Posted March 8, 2011 Author Posted March 8, 2011 Problem found, split pipe on compressor housing.
ciaranrb5 Posted March 8, 2011 Posted March 8, 2011 Where have you been hiding? That engine still in one piece then?
scooby222 Posted March 9, 2011 Posted March 9, 2011 its bound to be fine, never gets driven and i know - i thought he'd emigrated too!
