frankyboy Posted November 9, 2010 Posted November 9, 2010 my car has started stuttering so i cahnged the leads and plugs yesterday took it out this morning everything fine. coming home this evening car not boosting past 0.2bar and really lagging does it in all gears. when i put the foot down fast it doesn't want to move at all any ideas people
frankyboy Posted November 9, 2010 Author Posted November 9, 2010 p.s no smoke or noises coming from the turbo either
sinny Posted November 9, 2010 Posted November 9, 2010 maybe a long shot bud, but when i was having similiar problems like hesitation ect what got suggested on these forums to me was clean out the boost control solenoid using electrical cleaner, connect the green plugs under dash so the solenoid is operating and spray it clear, u will get the spray out the other port as it operates and let it all dry out before puting it back together, check tubing as well for oil particles, there is good write ups on this on the net, might not be your problem but worth a shot, hope you get it sorted.
frankyboy Posted November 9, 2010 Author Posted November 9, 2010 Where is the solinoide on the classic and what does it look like cheers
frankyboy Posted November 9, 2010 Author Posted November 9, 2010 Cleaned it and all the pipes still no joy runs a wee bit smoother but not boosting past 0.2
ciaranrb5 Posted November 9, 2010 Posted November 9, 2010 Where is the solinoide on the classic and what does it look like cheers It is next to the suspension turret drivers side has 2 pipes (possibly 3 depending on what car you have and what spec) and a plug connected to it one of the pipes goes to the actuator on the turbo and the other one to the inlet manifold
ciaranrb5 Posted November 9, 2010 Posted November 9, 2010 doh too slow. Try dissconnecting battery for 10 mins car sounds like it's in limp mode
frankyboy Posted November 9, 2010 Author Posted November 9, 2010 I'll try that just now then see if that make a difference mine is a 97 face lift would it have limp mode? Found the solinoide too
d3ekc Posted November 9, 2010 Posted November 9, 2010 hi mate might be a long shot but try your maf i had a prob the same and all i had to do was clean the maf or if you could borrow one from someone else just to check it
