GazTurboUK Posted September 28, 2010 Posted September 28, 2010 Ok my car is a 1998 uk turbo registered 07/08/98 according to plate on car its got an ej20gn engine but from what i can find online this engine was stopped in 97 and the car should have an ej20g engine instead which would have the thinner 0.6mm gasket unline the ej20gn which my car appears to have which would be 1.6mm Any ideas what one will be correct for mine? Old gaskets appear to be 1mm once removed after being compressed however the kits i am looking at with 1.6mm gaskets appear to be including spark plug seals for coil on plug where as my engine has centre coilpack on manifold. Mega confused Cheers in advance Gaz
StrikE Posted September 28, 2010 Posted September 28, 2010 No idea m8, someone will be along shortly with a bit more info than i could offer. Hope you get sorted tho
craigdmcd Posted September 28, 2010 Posted September 28, 2010 Is it to replace as standard head gaskets or do you have mods done to the car?
GazTurboUK Posted September 28, 2010 Author Posted September 28, 2010 Only mods i have so far is full decat stainless exhaust. Not planning any internal engine mods on this engine or mega boost. Cheers Del, got everything stripped down just need to get correct parts ordered then its time to go back in.
