Engine Code 45
got a 1995 wrx auto with engine code 45.
had some problems whilst high in the revs at overtaking type speeds at around 4 and half rpm. car would have a big poppy bang then rev counter needle would go right up then right down then the car willl settle. it's ok for toddling round the town speeds but when i give it the beans she's defo not happy.
had had a wee issue thinking it was spark plugs so having changed them and then changed them again then find i need 2 coil packs
engine management light never came on the hole time over this because . . . . . . . . their wasn't a bloody bulb in the dash.
have had dash out and bulb put in so the light does work now and i'm getting code 45. i looked at some of the codes and results i got for a 45 are pressure sensor or pressure duty solenoid.
could my coil packs that need replacing be making this code come out ?
hope you made sense of this post it's really hurting my brain :thumbup:
fingers crossed it's all good for the highland run.
Edited by empty_heed
