gavin_moore13 Posted February 9, 2010 Posted February 9, 2010 good evening all have a bit of a problem and was looking for some help.Over the xmas period woke up one morning took the car out and was driving when i decided to try full boost on motorway the car although boosting normal seemd hesitant as if some form of block. i took the car to greersport on monday for oil change and also to have a look at they changed the maf with 2 different maf's which seemed to help but not fully correct the problem. what i need is if someone is so kind to lend me a hand controller for the apexi so i can tak to greer's and they will plug into my apexi as neither myself nor them have one and hopefully this may be able to help me solve my woes the only onther option they can suggest is a trip to mr forrest and im not sure when i would get the time to do so. i will post my number below and im in paisley so any help would be much apprecieated. regards gavin 07961591819
green_goblin Posted February 9, 2010 Posted February 9, 2010 I would lend you my one if i was closer mate, im sure someone will be able to help you out!!
gavin_moore13 Posted February 9, 2010 Author Posted February 9, 2010 thanks for that mate just want the car back running asap
