1000cc Injectors Required
if its any help i can get you 4 x tube made up, 1/4 inch upto 1 inch by 16gauge or
you could use four triton shower heads they do them in steel which can with stand
alot of heat, have you tried gatwick :rotfl:
the problem is getting injectors to flow 1000cc not just called 1000cc
belive it or not its not quite the same thing so dont want to buy these then have to have them tested to make sure they have the correct flow rate
Just a thought Steve, can't Mark at Lateral open your existing injectors out, but I'm sure you've already researched that option. :rotfl:
cheers hugh spoken too mark and not some thing that can be done to 660s may have to bear with 1000s flowing 9s for now will still be good for up to 550ish but will have to wait for the e85
