20kendo Posted March 15, 2009 Posted March 15, 2009 Anybody fitted morette lights to a bugeye, looking for help please. Got a second hand pair on evilbay, sidelights and dips working fine but no main beams! Looked like a simple plug in job, morette plugs match the scoob plugs etc so looked like an obvious connection - no such luck! What have i missed ? kenny
20kendo Posted March 15, 2009 Author Posted March 15, 2009 Yep, it's a single filament bulb with single spade connector, nothing else in halfrauds even looked like it would fit in the reflector.
higgy Posted March 15, 2009 Posted March 15, 2009 you need to run a secondary supply with a relay. Higgy
20kendo Posted March 15, 2009 Author Posted March 15, 2009 Came with 2 relays passenger side 1 relay drivers side !
x444wrx Posted March 19, 2009 Posted March 19, 2009 Hi there mate iv fitted a pair of these to my 05 plate blob eye and had a very similar issue,drivers side worked perfectly and passenger side lights were all over the place,i ignored all connection plugs on the unit and added cables in paraell from the drivers side which was the easy option as i think there was an issue with the realays on the units,but hey ho they work fine and look the b******s now!!!
20kendo Posted April 5, 2009 Author Posted April 5, 2009 Finally got power to all of the lamps, just not in the correct way, high beams glow when on dips then go off completely when switch to full beams, driver side dip also seems to go duller than the other side, hard to be sure of that with it being very bright today, will check this again tonight, any ideas folks ?
