koolgraham Posted March 10, 2009 Posted March 10, 2009 hi just bought a hks turbo timer very nice one but fitted it in all well just found out alarm wont cut in when you fob it and helpers its a croba alarm
kentperformance Posted March 10, 2009 Posted March 10, 2009 You will find that the turbo timer will cause that problem with some alarms. The alarm is sensing that the ignition is still on, so not allowing you to arm it. It take it it arms ok once the timer has switched the ignition off?
koolgraham Posted March 10, 2009 Author Posted March 10, 2009 kentperformance said: You will find that the turbo timer will cause that problem with some alarms. The alarm is sensing that the ignition is still on, so not allowing you to arm it. It take it it arms ok once the timer has switched the ignition off? yer its goes off then i can alarm
koolgraham Posted March 10, 2009 Author Posted March 10, 2009 so are you a garage or something cause you seem to know a hell of a loot about subarus and if so where about is your garage
m@tt untimate STImulation Posted March 10, 2009 Posted March 10, 2009 hes kent performance in gillingham on the bussiness park did majic job of my gearbox
