flea Posted February 16, 2009 Posted February 16, 2009 ok my 96 wrx has not been bossting for about a month and flinging up maf fault code! what would/is happening is i get to about 4/5k revs and the car will dump loudly. ive replaced the maf reset ecu and its still the same! its completely standard bar a hks filter and blitz dump valve also the dump valve i noticed seems to be a bit sticky? ive never watched it work but to me it seems sticky. anyone (The SIDC Muppet-O-Tron has corrected your lazy use of the English language. Please use English and not text talk on thes any ideas and cures i could try so i can start eliminating things? cheers!
johnnyr6 Posted February 16, 2009 Posted February 16, 2009 It could be anything m8. What do you mean it will dump loudly? Is it losing power like hitting a wall at 4/5k? Is the dump valve a VTA? if so i would get rid and go back to the standard recirc. see if that helps. Another reason could be your coil packs. take them off and remove the rubbers and check for bad corrosion on the ends or cracking at the tips. good luck m8. Johnny.
