m@tt untimate STImulation Posted February 11, 2009 Posted February 11, 2009 i need a new gear box as soon as posible. any one got a working 1 reconditioned would be the best option or know some 1 or some were i can get 1 chepish. 1st head gasket now this i need help!!!!
granby Posted February 11, 2009 Posted February 11, 2009 Your not having much luck at the moment are you
m@tt untimate STImulation Posted February 11, 2009 Author Posted February 11, 2009 its killing me i only earn £200 aweek as an aprentice its becoming a real isue
emoe Posted February 11, 2009 Posted February 11, 2009 one problem i see here is the words you used WORKING RECON BOX and CHEAPISH!! they dont go together!! any box that is cheap is cheap for a reason and more than likely is already in need of refurb. You have to make sure you get the box with the same ratio as your rear axle or youll be in serious problems!!
kentperformance Posted February 11, 2009 Posted February 11, 2009 Depending on what's happened to yours, a repair of the damage might be more cost effective. Tbh, getting a cheap box is normally not the way to go with Impreza's.
Scooby Hoo? Posted February 11, 2009 Posted February 11, 2009 Depending on what's happened to yours, a repair of the damage might be more cost effective. Tbh, getting a cheap box is normally not the way to go with Impreza's. THIS IS SOUND ADVISE
yogi- Posted February 11, 2009 Posted February 11, 2009 THIS IS SOUND ADVISE Don't you just love Hugh's words of wisdom and one liners
m@tt untimate STImulation Posted February 11, 2009 Author Posted February 11, 2009 how do i get the ratio of my rear axel spaceman is selling 1 im looking to buy that £300 plus delivery. is that about right
m@tt untimate STImulation Posted February 11, 2009 Author Posted February 11, 2009 its comes with a center diff will that make it all work??? mine is a 1995 and its from a 1996
m@tt untimate STImulation Posted February 11, 2009 Author Posted February 11, 2009 this is the description of the box im terying to buy. Fresh Built Gearbox Ty252 Casing, ty254 internals (stronger uk gear set) Options Track this topic As above 252 casing with fresh rebuilt uk gear set and and all set up by Kenny Brown who does race cars just ask John ST Bough the box from Arch to repair my type ra but just sold that so box for sale not even been fitted to car yet £300 Any questions please ask and am sure arch or John will help me answer Should be a pretty strong gearbox and must be cheaper than a rebuild on yours comes with centre diff too greig can pallet to you anywhere in uk at your cost around 50-70 quid id think
j-k Posted February 11, 2009 Posted February 11, 2009 this is the description of the box im terying to buy.Fresh Built Gearbox Ty252 Casing, ty254 internals (stronger uk gear set) Options Track this topic As above 252 casing with fresh rebuilt uk gear set and and all set up by Kenny Brown who does race cars just ask John ST Bough the box from Arch to repair my type ra but just sold that so box for sale not even been fitted to car yet £300 Any questions please ask and am sure arch or John will help me answer Should be a pretty strong gearbox and must be cheaper than a rebuild on yours comes with centre diff too greig can pallet to you anywhere in uk at your cost around 50-70 quid id think you need to check the transmission code stamped on the nearside inner wing tag...it will start ty752 or ty754. You then need to check that number against the code on the top of the bell housing of the gearbox (adjacent to the clutch arm i think?) to make sure they both match.( in case the box has been changed before) These codes will give you your gear ratios and diff size. The diff size for the new box MUST match your existing rear diff set up. I hope this helps jon
j3rk Posted February 11, 2009 Posted February 11, 2009 Yeah get the gearbox checked out, could be repairable and cheaper. Talk to kent performance. They did my gearbox recently. KENT PERFORMANCE...TOP BOYS! Will i get discount now?
gary may Posted February 11, 2009 Posted February 11, 2009 i need a new gear box as soon as posible. any one got a working 1 reconditioned would be the best option or know some 1 or some were i can get 1 chepish.1st head gasket now this i need help!!!! .................OI MATT YOUR 5HITTING ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! WTF
m@tt untimate STImulation Posted February 11, 2009 Author Posted February 11, 2009 thanks for the help, need it !!! gunna try and find out the codes. anyone (The SIDC Muppet-O-Tron has corrected your lazy use of the English language. Please use English and not text talk on thes kno were i can get the ratios from
m@tt untimate STImulation Posted February 11, 2009 Author Posted February 11, 2009 how many types are there
j-k Posted February 11, 2009 Posted February 11, 2009 check out the transmission chart....Google is your friend!!! http://spda-online.ca/modules/tinycontent/rewrite/tc_28.html jon
20withascooby Posted February 11, 2009 Posted February 11, 2009 I wanna see how you drive your either unlucky or drive v bad
m@tt untimate STImulation Posted February 11, 2009 Author Posted February 11, 2009 it bein unlucky and the bloke i got it from must have abused it plus its got a 2.5 block so runnin more power than the gearbox is built for i think im defo gunna turn the boost down when its all done.
m@tt untimate STImulation Posted February 11, 2009 Author Posted February 11, 2009 thank you for you info. its helpin alot, its a 95 so more than likely a 4:1:1 hope so. thats the box i am currently looking at
m@tt untimate STImulation Posted February 11, 2009 Author Posted February 11, 2009 will have to go have a look at the weekend or get a person from the garage to look its a pain cz its in storage on the eurolink
j-k Posted February 11, 2009 Posted February 11, 2009 will have to go have a look at the weekend or get a person from the garage to look its a pain cz its in storage on the eurolink jack it up so that all four wheels are off the ground (make sure its safe!!) then if its 4.1diffs, for every one full turn of the wheels, you will get 4.1 turns of the propshaft. Or 3.9 turns of the prop for 3.9 diff? simple! jon
m@tt untimate STImulation Posted February 14, 2009 Author Posted February 14, 2009 its at kent performance now havin the gearbox out looking at getting it rebuilt so far so good
Montythegod Posted February 16, 2009 Posted February 16, 2009 Trust me.. I am on my fourth gearbox in last 2 years ......... an I drive it hard at 340bhp... I have changed from a ty752 to a ty754 based box and still cant take it... SAVE UP FOR AN UPRATED BOX.... I'm lucky I can change my own boxes, but I do have a spare ty754 box with a blown 2nd and 3rd if it helps in the recon stakes, any ty752 box is as much use as a chocolate fireguard! I took one to Star transmissions in strood and they fixed 2nd and 3rd last time for 350 quid, removal and refit included !
m@tt untimate STImulation Posted February 17, 2009 Author Posted February 17, 2009 well idealy i want 2 save up for a brand new 2.5 turbo engine from an 05plate and matchin 6speed gearbox but i don have that ash layin around and i gota get it sorted, its done 80k miles of abuse so its not a sh*t box.
