Help Asap Regarding Exe-tc
Guest CRAIG D
Guest CRAIG D
Hi Guys, i had a thought and desided that am going to fit me EXE-TC suspension Today but i just want to make sure that these top mounts are sitting the correct way.
Here is a pic of the top mount can i assume that where is says out that should go to the left hand side of he wing as you look at it?? or does it go to the right ?? and should the small arrow what sitting about 11 o'clock face the bulk head??
:o:hl:
No i havent been drinking again before sum1 slides that in :D
Or sum1 can give me a bell 07955142984
Edited by CRAIG D
Craig I have never fitted the exec but I would imagine that the LH one is for the LH side of the car with the out sticker facing outboard toward the wing if John is prowling around he may be able to help :o
Guest CRAIG D
Thanks for the reply guys i managed to get it sorted out and go all the suspension all fitted.
First impressions are good, i did have a moment tho just off the newbridge around about did abit if fishing (fish tailing about the road for about 20meters or soo i thought id seen my scooby days over again. :o
Unsure what caused it tho may have been some grease or i had the damping to hard???? I have them all at 20 clicks. Must say that the road noise have increased but am not fussed about that.
Need to get my front and rear ARB,Drop links,un lift kit fitted then get some1 to set it up has anyone got any suggestion on which company to use for this??
:D:hl:
Guest CRAIG D
Progrip are down your neck of the woods, they seem to be highly recommended :D
Ah progrip thats the one. Thanks :o
Something aint right with the suspension tho its very very twitchy, il need to get it sorted a nice trip to progrip mine just do it HOPFULLY.
Has anyone with EXE-TC have the information regarding setting to use??????
Craig, ring Graham Gleeson at Exe-tc direct... He's usually very helpful and can probably point you in the right direction for a base setup..
I haven't got his number anymore but have his email.. graham.gleeson@exe-tc.co.uk
remember you have just bolted on a set of coil overs with someone elses camber adjustments and your car has not been set up to suit them. Until you get the car aligned it will handle like ****.
Progrip is the only place I would take my cars for an alignment :o
:hl::D
Prob my dodgy welding on the rear end putting it out of align. :D
Guest CRAIG D
Prob my dodgy welding on the rear end putting it out of align. :hl:
Ah true enuff son, :D was a cracking joke and you fell for it too :o
:D
Edited by CRAIG D
Guest CRAIG D
Ah perfect il give him a bell in the morning thanks m8 :o
Guest CRAIG D
Yeah very true i must admit i didnt thing about that :D Am going to give progrip a bell tomorro as it very very twitchy and dont really fancey crash it :hl:
Note to self MUST NOT CRASH :D
Edited by CRAIG D
