Braided Fuel Lines
Guest CRAIG D
Guest CRAIG D
EVENING,
Iv decided not to get the RA ready for 2009 as there is still far to much to do on the car, So am gona strip the engine bay down and clean the bay up and sort alot of the wiring out. I also want to remove the fuel tank and get a decent fuel cell in the boot. I also want to run the brake pipes in stainless steel.
Has anyone got any info on size of fuel lines i need to get. I know the brake lines are 1/4".
any pics or help would be nice.
Thanks
if your looking to replace your fuel lines etc it may be worth speaking to alyn at as performance/trading.
i'm sure i'm using 8mm lines on mine but not sure if thats the standard size
EVENING,
Thanks
hi m8 heres brake lines aeroquip
fuel system
all my brake hose and ends are from demon tweeks
fuel hoses bsh hydraulics in grangemouth 8mm id 10 od geo
Guest CRAIG D
Iv just got the new 2009 demon tweeks catologe today soo been having a wee look throught it.
Cusco kid, I take it youve still got the standard fuel tank?
so 8mm hoses for the fuel lines + Brake lines??
Il need to have a good look throught the book and get this all ordered b4 xmas
Speak to Alyn m8 as he is dong a discount on Goodridge stuff now.
8mm fuel lines and standard 4.75mm brake pipes
you can spend a fortune on aeroquip fuel pipe ends or go for the type i used from BSH in grangemouth geo
Guest CRAIG D
Thanks m8,
have you got a number for BSH.
Thanks
would there be any harm in doing fuel lines 6mm hard stainless pipe as i can basically get free fitting and all the necessary tools offshore. And do most fuel line join using NPT or BSP type connectors?
hi m8 6mm would be too restrictive on flow you need at least 8mm id geo
Thanks m8,
Thanks
hi the no is 01324 4474242 ask for stevie tell him geo from merc gave you his phone number
if you want a look at my set up your welcome to come over to take a look geo
could just use 10mm then as we have that aswell :lol:
I just thought 6mm as it is easiest to work with
