Urgent Help Needed
Hi there,
I have a problem with the side lights and rear lights on my Classic impreza, they are both not working anymore.
As both side lights and rear lights have went out at once i take it they work off the same fuse, thing is I have checked both fuse compartments in the car (ie under the bonnet and under steering wheel) but cant find the fuse that I need to replace.
Anyone know which fuse it is, any help would be much appreciated as I cant drive car at night just now due to no rear lights.
Thanks
James
Is there no indication on the fuse box cover to tell you which fuse is which. Usually by a small symbol for each fuse slot. Then the owners manual tells you which each symbol means, most are self explanitary though.
I dont have my scoob just now or i would go and have a look to see which fuse it is your seeking.
Rich
Rich
The underside of the fuse box cover tells you what most of the fuses are for but it doesnt say anything about rear lights or side lights
john it could be the actual lighting switch fuse, as the left and right hand headlights are individual fuses,no27 and 28 in the engine compartment fusebox(15Amp) the lighting switch fuse is a no.29(20amp) located in the same box.the rear/taillight fuse is no.5 (10amp) located in the fusebox under the coin tray ,(right hand side of steering wheel).
hope this helps mate.
It's a yellow 20 amp fuse m8, just went out to my classic and started pulling fuses buddy, just read your post :lol:
Yellow fuse on the right, second from the top when it is removed the side and rear lights go oot, hope its the fuse
Edited by StrikE
hey there mate thanks very much indeed for doing that mate really appreciate it.
Just tried replacing the fuse but they still aint working, im pulling my hair out here dont know what else to try.
Just replaced this fuse mate, and the rear lights are working again, still cant get the sidelights working but im not that concerned with them at the moment, as the headlights work fine.
Thanks again for your help mate and big thanks to Strike as well
cheers
james
