Cel Help Please
Hi guys, any info on what's going on here? Just got a new clutch fitted. I know that the heat sensor on the CAT got damaged during the refit & the warning light is on, That's understandable. The main issue is that on idle, the CEL shows up! If I even just touch the throttle slightly, it goes out. have checked all fluids as I thought it may be low on oil pressure or similar, but all seems OK. Any ideas or is it a take to the garage job?
J
Edited by big j
Hi guys, any info on what's going on here? Just got a new clutch fitted. I know that the heat sensor on the CAT got damaged during the refit & the warning light is on, That's understandable. The main issue is that on idle, the CEL shows up! If I even just touch the throttle slightly, it goes out. have checked all fluids as I thought it may be low on oil pressure or similar, but all seems OK. Any ideas?
J
Hi mate, your best bet is to plug in the two black plugs under the steering wheel,looking up from the pedals.
Turn on ur ignition and the CEL light should do a series of flashes,(long ones,short ones)if you get a list of the fault codes these flashes will tell you the stored fault.
Brian.
OK, tried the black connectors, just got a constant "tone" without and with ignition on. No lights without ignition & normal with it on :s
J
Edited by big j
Don't want to be a PITA, But is there anybody who can diagnose this in the evenings or weekends that is reasonably close to Lanark?
J :thumbup:
i can do it for you m8 depending on what year the car is if its a 99 onwards then i will do it for you just drop me a pm am and i will do it saturday for you
