b4z Posted October 14, 2008 Posted October 14, 2008 Hi folks after some advice. Car comes on boost and pops bangs and miss fires got 2 fault codes. Crank sensor ( crank seal is leaking this will explane that fault and is gettin changed). Other is maf sensor. Has anyone has similar problems? if so my car is an early classic been told 2 put a later one on and this will handle more boost is this true??
phil_g Posted October 14, 2008 Posted October 14, 2008 (edited) Dont you mean a 97>00 map sensor or the Nissan MAF upgrade ? If it is one of them, then its a remap. Ive got both those fitted on mine and remapped by Andy F. Edited October 14, 2008 by phil_g
b4z Posted October 14, 2008 Author Posted October 14, 2008 Dont you mean a 97>00 map sensor or the Nissan MAF upgrade ?If it is one of them, then its a remap. Ive got both those fitted on mine and remapped by Andy F. yes. what is the nissan maf upgrade? a work at a dealers so can get one no problem. if u change maf type do u always need a re map??
phil_g Posted October 14, 2008 Posted October 14, 2008 (edited) If your MAF housing is 80mm then the Z32 will fit straight on, if its 90mm then the Q45 will fit straight on. Both need a loom modification and a remap. They are much more reliable and good for high bhp. The wiring is straight forward. Z32 connector has 6 pins labelled A to F: A - Not connected B - MAF Output Signal C - Gnd D - Gnd E - +12V F - Not connected Subaru 92-96 MAF Connector has 5 pins: 1 - +12V 2 - Gnd 3 - Sensor Gnd 4 - MAF Signal 5 - Not connected just make sure you keep the gnds separate. For the Q45 http://bbs.22b.com/cgi-bin/ultimatebb.cgi?...t=001051#000000 If memory is correct early map sensor is up to 1.1bar and later is 1.4 bar For the map sensor http://bbs.scoobynet.com/general-technical...-me-please.html Edited October 14, 2008 by phil_g
b4z Posted October 14, 2008 Author Posted October 14, 2008 thanx think it will be std one for now its the early model one need 2 get hold of one
