A Little Help Needed Please!
Right just got the car back from the garage getting bits n bobs (non engine related) sorted and its MOT sorted out but coming home the check engine light came on and i parked up left went to use it yesterday fine no probs no check light or anything. then this morning went to go to work and it comes on again! so im a bit confused :thumbup:
Rang the garage and he has said to check the ipe from the Maf to turbo and clean out the maf.
So has anyone had this problem before?
its a MY95 WRX btw!
cheers
Fly.
its a MY95 WRX btw!
cheers
Fly.
Personally would be getting the garage to run a free diagnostic on it.
It does appear that they have disturbed a sensor of some kind. It's difficult to
say what to check without knowing the fault tho.
Craig.
WELL!......
decided i couldnt have all those faults so decided that id reset the ecu and take her a run and its came back all clear!!!!!
could this have been the previous engines faults before it was replaced?
WELL!......
it could well be mate
however
resetting the ECU means you have cleared the faults fronm the memory , if they have been fixed you wont get the light come up again, you might also find that the light will come back on if the fault is still there, time will tell, i suppose
craigy
