Brake Pads?
any body got a old set for standard classic laying about not worried if they are low i want tp try sumthing as i have a noise dazz thinks its sqeel pin but i dont think it is wanna just put em on and see if it stops or not
if youre getting Squeal, its three things that can cause it. the old Slider type calipers are terrible for it!
Firstly, clean out the calipers and pads well, as dust can cause it.
Second, the pads are glazed causiing the squealing
third, you have ridged discs and the edge is vibrating under braking.
Putting an old set on may not actually fix the problem or give you any clues.
Check the discs, if they are ok, then buy some decent Ferrodo pads, or EBC red stuff, and clean off the claipers really good
i do get vibration when im braking hard somtimes i knew the pads were getting a bit low anyway but they not griding sounds like a stone or sumthing going round in my whele but more sqeekey
Sounds to me like you need new discs too, they probably got hot and warped a bit, so change both and your problems will go away!! :D
