Urgent Help Needed
Hi there,
My passanger side headlight was recently broke, so i decided to order a set of Crystal Style Headlights (manual one), for 98 Classic Impreza
I went to fit them I noticed that there is no motor with the plug on them, so I removed motor from the old headlights, but the new ones have some large adjustable screw sitting where the motor should go, which means I cant get the motor fitted on them.
Tried to remove the screw but it appears to just turn so much then stick, think it may be an adjuster for the new lights.
Anyway to cut a long story short was wondering if anyone else has fitted these or knows of a way to get round this problem.
Thanks
James
When you buy the lights you have a choice of electric height adjustable or not. The question is how often you change the height beam of the lights, probably not that often or not at all, so just adjust the height of the manual one you have.
Yeah just realised that I had electric height adjust :P feel abit stupid now, ha ha.
Thats them fitted now anyway, but I think I may have broke the adjuster on one of them :D but they appear to be working fine.
James
The ball might have popped out of the adjuster, but don't even try to get it back in! Nightmare, unless you can get the lens off the front and pop it back in. Just check the beam doesn't flap about up and down when you're driving and you'll be fine.
