On Going Problem
After getting code 24 and 33 and the engine check light coming on, I have replace the idle control solenoid and the codes are still showing. I am a bit stuck and very reluctant to take it to my local subaru dealer.
Any suggestions folks?
Sounds like a wiring problem than an item problem. Have you checked you'rre getting a feed to the ISCV and speed sensor? Checked the connections are secure?
not yet but that sounds like a good place to start. The connections seem ok but I will check if it's getting power. 12v a take it?
