Vehicle Speed Sensor And Idle Sensor?
Hi guys...Got a day off and need to sort out some gremlins.
These are my 2 fault codes I'm getting. No 24 and 33. (Vehicle speed sensor and ICV sensor)
Would a speed sensor fault be caused by my lack of speedo due to damaged instrument panel (no speedo)?? Or is it driven by a cable??
Also I'm just cleaning out and adjusting the idle valve sensor, may have to replace it.
I take it the check engine light puts the car into safety mode hence the rev limit and boost cut??
Thanks again.
Thanks again.
hi tony, speed sensor is on the gearbox, it is not a mechanical cable,
check light will cut power down to stop you over doing it.
