My Car Has Died
well went out to my car today to move it to wash it again and it wont start its turning over but just wont fire up cleaned crank sensor just unplugged battery guna leave it a hour to reset as i was meant to do this when i fitted the z4 and didnt tried buming it and it dont wanna no any ideas would be weird for all 4 coil packs to shut down at once ?????
It's highly unlikely for all 4 coil packs to go at once, have you checked that the fuel pump is priming? (Sit in car with doors closed and turn key to on position w and you will hear it whirring) If not then try checking the earth cable that goes to it this is a common fault with imports it seems... (lift up rear seat and on driver side there is a connector block with the wires in it, it's the thick black one from what I can remember.....) mine was burnt out and had had the live reconnected but the earth had been left in it and had just carried on deteriorating :blush: leaving me stranded in Asda car park lol ;)
will be checking tmoz guna borrow a fuel pump and no its not whining so tht will all be checked tmoz how do u get bk seat up do u just pull the bottom bit up first????
undo the front 2 bolts an remove seat mate then you can undo the 2 bolts for the back rest remove that an the boot floor an you will see the plates undo them check the wiring if its not whirring at all also check all fuses dont no which one it is but you have some down by drivers feet an also under bonnet ;)
undo the front 2 bolts an remove seat mate then you can undo the 2 bolts for the back rest remove that an the boot floor an you will see the plates undo them check the wiring if its not whirring at all also check all fuses dont no which one it is but you have some down by drivers feet an also under bonnet :brickwall:
If it's the earth which it could well be if there's no sound coming from the pump, then you will only have to take the bottom part of the seat off and reconnect the wires outside the connector that is already there - mine had got so hot at one point it looked like it had caught fire as the underneath of the seat was all melted!!!
Mine went exactly the same way in clackets last october, run fine one minute and wouldn't start the next, Thanks to Arron who had a spare pump it was replaced and working in minutes, quick job to do.
I remember that day well :D
minutes took me two bloody hours and 5 fone calls for info lol
