scooby98 Posted March 16, 2008 Posted March 16, 2008 hi all can anyone help me out with this. i finished work this morning went to start my car and it just turned over slow as if the battery was flat. but its not it done this twice and then i noticed the check engine light flashing so i left it afew seconds and tryed again and it started fine.i drove home fine about 8 miles.i turned the car off and on to see if it was ok starting when it was warmed up and it started fine.but on turning the key i can hear a noise inside the car like sum thing is turning on.
swifty1981 Posted March 16, 2008 Posted March 16, 2008 hi all can anyone help me out with this. i finished work this morning went to start my car and it just turned over slow as if the battery was flat. but its not it done this twice and then i noticed the check engine light flashing so i left it afew seconds and tryed again and it started fine.i drove home fine about 8 miles.i turned the car off and on to see if it was ok starting when it was warmed up and it started fine.but on turning the key i can hear a noise inside the car like sum thing is turning on. it could be that you have some bad connections to the starter motor my classic did it to me last year. i dissconected the connections put them back on and it was fine after that. or it could be that your starter is on its way out
scooby98 Posted March 16, 2008 Author Posted March 16, 2008 it could be that you have some bad connections to the starter motor my classic did it to me last year. i dissconected the connections put them back on and it was fine after that. or it could be that your starter is on its way out i think it may be the fuel pump on the way out as i can only hear the noise in the car and not out side.
dazzlers82 Posted March 16, 2008 Posted March 16, 2008 i think it may be the fuel pump on the way out as i can only hear the noise in the car and not out side. that would not make it turn over slow mate as already aid could have bad connections or starter lazy
scooby98 Posted March 17, 2008 Author Posted March 17, 2008 that would not make it turn over slow mate as already aid could have bad connections or starter lazy had the cars checked out last night fuel pump was nackerd.
