The Guru Posted February 3, 2008 Posted February 3, 2008 Just feeling the water on this one. I have a Richard Bulmer mapped GEMS ECU with anti-lag and launch control etc this is currently on my tarmac rally car running the latest software. It is the very rare 4 plug version so it will fit all early cars from 1992-1996. The GEMS Subaru Impreza Plug N Play ECU's are being extensively used in rallying across the world and have proven themselves time and again. These are fully pin-to-pin compatible with the standard looms. The systems are fully programmable, retaining all calibration data in a secure re-programmable media known as an EEPROM, which allows those who wish to develop their own calibration the freedom to do so without ever having to open the ECU. The systems can also be configured to be EPROM-based for those customers who are not computer literate, but want to be kept up to data with the latest releases of calibration. The systems are very versatile allowing all the standard sensors to be used. The users are also able to select the type of load measurement; airflow meter or manifold absolute pressure (MAP). Anti-lag control (ALS) and launch control of the turbo-charger is provided. The ECU is fitted with specialist racing software based around the techniques used in the GEMS racing engine management systems. These 'hardware implants' are user friendly systems which require a minimum of electrical knowledge to operate. Features: Comprehensive Anti-Lag System Launch Control Rev light configuration Internal Logging Facility Twin channel VVC Inputs: Engine speed and position Map or airflow meter Air temperature control Barometric pressure Throttle position ALS switch Launch control switch Oxygen sensor monitoring Knock monitoring Vehicle speed Derived gear positon Outputs: 4 x injectors Idle motor control/ALS Fuel pump and speed control 4 x ignition outputs EGR valve control for ALS Wastegate control 2 x radiator fan control Water spray/injection 2 x rev lights Tacho Two Cooling Fan Speeds As I said I am just feeling the water at the moment but with enough interest the Ecu would be up for sale in the next few weeks. If you are interested please contact me via PM please. Arron.
dazzlers82 Posted February 3, 2008 Posted February 3, 2008 anti lag sounds good to me who is gonna chip in an help me pay for this
granby Posted February 3, 2008 Posted February 3, 2008 anti lag sounds good to me who is gonna chip in an help me pay for this I'll lend you a few.....................................................pennies
20withascooby Posted February 4, 2008 Posted February 4, 2008 tht sounds like a lot of fun launch control,anti lag a boy can only dream
