barry wemyss Posted January 6, 2008 Posted January 6, 2008 ok i have a 1999 s reg 2000 awd turbo (is this what is called a uk turbo ??) sorry new to subaru ownership when i start the car first thing it is lumpy to drive even after 4 or 5 mins to warm up and now and again when the temp gauge is half if i accelarate it is like it cuts out or struggles to get power but then it is ok any ideas please the car is going to subaru to get pressure tested tommorow and it is approach 90k so a service is due soon but if it is serious then the service will need to wait cheers baz
barry wemyss Posted January 6, 2008 Author Posted January 6, 2008 Could be fuel issues mate might be fuel pump on its last legsGordy ok is that a big job for it to be changed i think it might be worth a change as it is hitting 90k unless some one can convince me that they are lonh lasting i have had the car 5 months and covered about 8k miles
barry wemyss Posted January 6, 2008 Author Posted January 6, 2008 Took me about an hour or so to do myself it might not be that whats causing your problem tho!!but if your going to change it get yourself a walbro 255 pump Gordy cheers will look in to that and also when i start the car i get a lot of smoke this is not normal i have topprd up my oil but i think i put to much in
thefastone Posted January 15, 2008 Posted January 15, 2008 Hey Barry did you get your problem sorted with your car mate? was just reading this topic and was reading another thread the other day that I thought might be of some use if you still have the same problem... Read This thread here... as this sounds like the problem that you may be having...
