neill54 Posted January 5, 2008 Posted January 5, 2008 my cel has came on in my 92 wrx going for its mot on monday too car has been sitting for about a week without being started has always been fine not really missed a beat in the 18 months ive had it it needs a service and a small hole in the exhaust at the cat section needing patched just wondered if there could be anyything else and how do i find out what is wrong with it before i need to take it to a garage thanks neil
neill54 Posted January 5, 2008 Author Posted January 5, 2008 update: ive just found and read the article in an earlier thread about connecting the read connectors i take it these are under the dash at the steering colum? neil
neill54 Posted January 5, 2008 Author Posted January 5, 2008 another update: got a code reading of 22 so its a new knock sensor so its not that bad i suppose just need to find where it is and get one fitted!! neil
Carson Posted January 6, 2008 Posted January 6, 2008 Get the sensor, fit it! ~ new one, not ebay reset ur ecu if u know how see if its all good in the hood
neill54 Posted January 6, 2008 Author Posted January 6, 2008 i can maybe manage the ecu reset locate and fit the sensor but what i would like to know is what is knock and how has the engine decided to feck this sensor? neil
AlanG Posted January 6, 2008 Posted January 6, 2008 knock is detonation within the engine and is detected by a sensor on top of the engine. This then tells the ecu to retard the ignition timing to alleviate detonation. *Most likely* it's not the sensor itself but *probably* the connector to the sensor. Have a look there first before buying another sensor and check the resistance of the sensor to see if it is faulty.
neill54 Posted January 6, 2008 Author Posted January 6, 2008 cheers alan im just on the way out the door to get working on it neil
