yogi- Posted November 29, 2007 Posted November 29, 2007 Are the rear disc pads easy to change on a new age seeing as there is a cable to the caliper. Is there a caliper release tool needed??? my reson for asking is i have just relined the brakes on my van but i needed a special release tool to squeeze and rotate the pistons. Thanks
mickyw1 Posted November 29, 2007 Posted November 29, 2007 Are the rear disc pads easy to change on a new age seeing as there is a cable to the caliper. Is there a caliper release tool needed??? my reson for asking is i have just relined the brakes on my van but i needed a special release tool to squeeze and rotate the pistons.Thanks Yeah What you do is Get a bucket then a sponge with perhaps a bit of water and washing up liquidthen you WASH the wheel ( I know it sounds hard but you will get used to it ) Then you will be able to see what your doing !!
dazzlers82 Posted November 29, 2007 Posted November 29, 2007 Yeah What you do is Get a bucket then a sponge with perhaps a bit of water and washing up liquidthen you WASH the wheel ( I know it sounds hard but you will get used to it ) Then you will be able to see what your doing !! lol
yogi- Posted November 29, 2007 Author Posted November 29, 2007 (edited) Edited November 29, 2007 by yogi-
col_2 Posted November 29, 2007 Posted November 29, 2007 not sure if this is any help, but ive seen a few now on forecourts of garages
Scooby Hoo? Posted November 29, 2007 Posted November 29, 2007 Sorry Yogi but I have just wet my pants with this thread.
yogi- Posted November 29, 2007 Author Posted November 29, 2007 (edited) Sorry Yogi but I have just wet my pants with this thread. Oh i'm sorry to hear about you're Incontinence problem Hugh, you should get it checked out if i were you, or alternatively try a Nappy Edited November 30, 2007 by yogi-
yogi- Posted November 29, 2007 Author Posted November 29, 2007 not sure if this is any help, but ive seen a few now on forecourts of garages Who asked you anyhow
col_2 Posted November 29, 2007 Posted November 29, 2007 Who asked you anyhow im really sorry, but i thought this was a car club where people can give others advice, & i thought i was helping, ive read some of the threads & noticed some members have got a few problems, & i cant understand why certain members are wetting them selfs & others cant see where there driving its all abit worrying
granby Posted November 29, 2007 Posted November 29, 2007 im really sorry, but i thought this was a car club where people can give others advice, & i thought i was helping, ive read some of the threads & noticed some members have got a few problems, & i cant understand why certain members are wetting them selfs & others cant see where there driving its all abit worrying lol
scoob fae ork Posted November 29, 2007 Posted November 29, 2007 Hi mate if you look at your caliper there is 2 pins that hold the pads in on these pins are 2 R pins if you remove them you can then remove the main pins once you have done this remove the steel plate and then your pads should just lift out if there sticky its just a case of work at them with pliers till they come out the top. As for your Calipers there is 2 bolts on the back of the hub remove them and the caliper will lift off .
baser999 Posted November 29, 2007 Posted November 29, 2007 Are the rear disc pads easy to change on a new age seeing as there is a cable to the caliper. Is there a caliper release tool needed??? my reson for asking is i have just relined the brakes on my van but i needed a special release tool to squeeze and rotate the pistons.Thanks Give Yogi a break....he asks what is surely a sensible question and everyone takes the peeeeee. Oh, by the way, I haven't got a clue about changing the pads, sorry
yogi- Posted November 30, 2007 Author Posted November 30, 2007 Hi mate if you look at your caliper there is 2 pins that hold the pads in on these pins are 2 R pins if you remove them you can then remove the main pins once you have done this remove the steel plate and then your pads should just lift out if there sticky its just a case of work at them with pliers till they come out the top. As for your Calipers there is 2 bolts on the back of the hub remove them and the caliper will lift off . Just like that (Tommy Cooper) Thanks for that
Scooby Hoo? Posted November 30, 2007 Posted November 30, 2007 Give Yogi a break....he asks what is surely a sensible question and everyone takes the peeeeee. Oh, by the way, I haven't got a clue about changing the pads, sorry Yogi's the one who doesn't clean his wheels, NOT ME.
