big rob Posted November 2, 2007 Posted November 2, 2007 does any 1 know a place that skims brake discs nr sittinbourne ish ? got a bit of glazing on mine and they are squeaking
Deano 666 Posted November 2, 2007 Posted November 2, 2007 Hi rob i dont know of a place that will skim your discs, but i can supply you either standard or up-graded discs, if you are interested contact me by looking at my profile and click on my website.
granby Posted November 2, 2007 Posted November 2, 2007 I wouldn't recommend skimming brake disc's as it means there is less metal to dispense the heat which could lead to your brakes overheating and fading
Deano 666 Posted November 2, 2007 Posted November 2, 2007 I wouldn't recommend skimming brake disc's as it means there is less metal to dispense the heat which could lead to your brakes overheating and fading It can also remove the heat treaded surface of the disc face that prevents distortion.
big rob Posted November 2, 2007 Author Posted November 2, 2007 it seems a waste the discs aint that old
